Voici le code commenté permettant de tester facilement vos beaux potentiomètres tout neufs avec votre Gamebuino.
Si vous souhaitez apprendre à réaliser ce programme par vous-même où n’arrivez pas à comprendre le code commenté brut (quand on débute c’est un peu sec, ça ira mieux avec un peu d’habitude) vous pouvez suivre notre incroyable Tuto pas-à-pas : potentiomètres
* Code by Tom from Gamebuino
* V 1.0 16/05/2021
* Free to use and share
//we include the math library to get access to sin() and cos() functions as well as a value of PI used in the program
#include <math.h>
//variable declaration for the potentimeters values and their conversion to angle
int32_t i32_L_pot_value;
int32_t i32_L_pot_angle;
int32_t i32_R_pot_value;
int32_t i32_R_pot_angle;
//variable declaration for the points used to draw lines
int16_t i16_L_point_x;
int16_t i16_L_point_y;
int16_t i16_R_point_x;
int16_t i16_R_point_y;
//define of the analog pins used to plug the potentiometers, here A1 for left and A2 for right
#define L_POT_PIN A1
#define R_POT_PIN A2
//define of our circle properties, here it has a radius of 15 and is centered on the screen
#define CIRCLE_R 15
#define L_CIRCLE_X gb.display.width()/4
#define R_CIRCLE_X (gb.display.width()/4)*3
#define CIRCLE_Y gb.display.height()/2
while (!gb.update());
// the read_and_calc function will handle the data acquisition and math needed for the program
read_and_calc();
//the draw_interface function will handle the display of all the elements needed for the program
draw_interface();
void read_and_calc(){
// we read the value from the potentiometer plugged to the analog port A1
i32_L_pot_value = analogRead(L_POT_PIN);
i32_R_pot_value = analogRead(R_POT_PIN);
// we convert the value from a range of 0 to 1023 to an angle within 360 degrees
i32_L_pot_angle = (i32_L_pot_value * 360) / 1023;
i32_R_pot_angle = (i32_R_pot_value * 360) / 1023;
// we calculate the coordinates of a point on the circle perimeter corresponding to the value of the angle found above
// note the multiplication by PI/180, this is because the angle we calculated in degrees must be converted to radians
i16_L_point_x = L_CIRCLE_X + CIRCLE_R * cos(i32_L_pot_angle * M_PI/180);
i16_L_point_y = CIRCLE_Y + CIRCLE_R * sin(i32_L_pot_angle * M_PI/180);
i16_R_point_x = R_CIRCLE_X + CIRCLE_R * cos(i32_R_pot_angle * M_PI/180);
i16_R_point_y = CIRCLE_Y + CIRCLE_R * sin(i32_R_pot_angle * M_PI/180);
void draw_interface(){
// we print the value read from the potentiometer and its value when converted to an angle
gb.display.setCursor(gb.display.width()/2 - 12, 0);
gb.display.printf("Values");
gb.display.setCursor(gb.display.width()/2 - 12, gb.display.height() - 6);
gb.display.printf("Angles");
//raw values display
gb.display.setCursor(gb.display.width()/4 - 5, CIRCLE_Y - CIRCLE_R - 7);
gb.display.printf("%d", i32_L_pot_value);
gb.display.setCursor((gb.display.width()/4)*3 - 5, CIRCLE_Y - CIRCLE_R - 7);
gb.display.printf("%d", i32_R_pot_value);
//angles' values display
gb.display.setCursor(gb.display.width()/4 - 5, CIRCLE_Y + CIRCLE_R + 5);
gb.display.printf("%d", i32_L_pot_angle);
gb.display.setCursor((gb.display.width()/4)*3 - 5, CIRCLE_Y + CIRCLE_R + 5);
gb.display.printf("%d", i32_R_pot_angle);
// we draw the circle with the properties we defined at the beginning, its center's position and radius
gb.display.drawCircle(L_CIRCLE_X, CIRCLE_Y, CIRCLE_R);
gb.display.drawCircle(R_CIRCLE_X, CIRCLE_Y, CIRCLE_R);
// we draw a line between the center of the circle and the point on its perimeter corresponding to the potentiometer value we read
gb.display.setColor(RED);
gb.display.drawLine(L_CIRCLE_X, CIRCLE_Y, i16_L_point_x, i16_L_point_y);
gb.display.drawLine(R_CIRCLE_X, CIRCLE_Y, i16_R_point_x, i16_R_point_y);
Vous êtes libres de le modifier à votre convenance et de le partager.![démo_pot_code|375x500]
