I post here a solution posted by @Steph, 2 years ago to make animation with a concrete example, treated in its entirety.
First to add an image in your game you can have a look on this tutorial
This example will allow to better understand how to make a sprite animation. Here is a spritesheet that breaks down the progress of a well-known character, which includes 10 images (right-click and then « save image as » to retrieve it):
You will find the original spritesheet on spriters-resource.com. Thanks to Ittan-Momen.
The animation has 10 frames. Each frame measures 20x32 pixels. You can convert this spritesheet to C++ using the Image to code converter tool of our friend gouz. All frames are oriented to the left, but it is useless to copy them by symmetry to obtain the versions oriented to the right. Indeed, you will see below that the drawImage function accepts two optional parameters (w2 and h2) that will allow you to reverse images horizontally.
You will find below a small code detailing an animation technique of the character walking, controllable with the BUTTON_LEFT and BUTTON_RIGHT buttons on the console. Here is a screenshot of what it looks like:
The corresponding code will be posted on next post as else this one is too long:
#define SCREEN_WIDTH 80
#define SCREEN_HEIGHT 64
#define MARIO_WIDTH 20
#define MARIO_HEIGHT 32
#define MARIO_FRAMES 10
#define MARIO_DEFAULT_FRAME 4
#define MARIO_ORIENTATION_LEFT true
#define MARIO_ORIENTATION_RIGHT false
const uint16_t mariodata[] = {
MARIO_WIDTH, // frame width
MARIO_HEIGHT, // frame height
MARIO_FRAMES, // number of frames
0, // animation speed (no animation)
0xF81F, // transparent color
0, // color mode: RGB565
// colored pixels data
0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xec66,0xe184,0xe184,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xe184,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0x80c1,0x80c1,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xe184,0x80c1,0x80c1,0x80c1,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x80c1,0x80c1,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0x0,0xffdd,0x0,0xffdd,0xff5a,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0xff5a,0x0,0xffdd,0xff5a,0xf616,0xf616,0x0,0xf616,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xffdd,0x0,0xffdd,0xff5a,0xff5a,0xff5a,0xf616,0xf616,0x0,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xf616,0xf616,0x0,0x0,0x0,0x0,0x0,0xf616,0x0,0xf616,0xf616,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x80c1,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x949e,0x0,0x80c1,0x80c1,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0xe184,0x0,0x949e,0x0,0x0,0x0,0x80c1,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x949e,0x949e,0x0,0xec66,0xffdf,0x0,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x949e,0x0,0x0,0x0,0x949e,0x949e,0x0,0xffdf,0xffdf,0xffdf,0xffdf,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x949e,0x0,0xff50,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x949e,0x0,0xff50,0xff50,0xff50,0xff50,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x7399,0x949e,0x949e,0x949e,0x949e,0x949e,0x949e,0x7399,0x0,0xff50,0xff50,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x4a51,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x4a51,0x4a51,0x4a51,0x4a51,0x4a51,0x0,0xec66,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0xec66,0xe184,0xe184,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0xe184,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xe184,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xe184,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xec66,0xe184,0xe184,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xe184,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0x80c1,0x80c1,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xe184,0x80c1,0x80c1,0x80c1,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x80c1,0x80c1,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0x0,0xffdd,0x0,0xffdd,0xff5a,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0xff5a,0x0,0xffdd,0xff5a,0xf616,0xf616,0x0,0xf616,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xffdd,0x0,0xffdd,0xff5a,0xff5a,0xff5a,0xf616,0xf616,0x0,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xf616,0xf616,0x0,0x0,0x0,0x0,0x0,0xf616,0x0,0xf616,0xf616,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x0,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0xe184,0x0,0x0,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x949e,0x0,0x80c1,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x949e,0x0,0x0,0x0,0x949e,0x949e,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x949e,0x0,0xffdf,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x0,0xff50,0xffdf,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x7399,0x949e,0x949e,0x949e,0x949e,0x949e,0x0,0xec66,0xff50,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x4a51,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x0,0xec66,0xff50,0xffdf,0xec66,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x4a51,0x7399,0x7399,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0xec66,0xe184,0x80c1,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xe184,0xe184,0xe184,0x80c1,0x0,0xF81F,0xF81F,0x0,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xff50,0xff50,0xe184,0xe184,0x80c1,0x80c1,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0xff50,0xff50,0xff50,0xff50,0x0,0xec66,0xe184,0x80c1,0x80c1,0x80c1,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0xe184,0xe184,0xe184,0x80c1,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xec66,0xe184,0xe184,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xe184,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0x80c1,0x80c1,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xe184,0x80c1,0x80c1,0x80c1,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x80c1,0x80c1,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0x0,0xffdd,0x0,0xffdd,0xff5a,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0xff5a,0x0,0xffdd,0xff5a,0xf616,0xf616,0x0,0xf616,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xffdd,0x0,0xffdd,0xff5a,0xff5a,0xff5a,0xf616,0xf616,0x0,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xf616,0xf616,0x0,0x0,0x0,0x0,0x0,0xf616,0x0,0xf616,0xf616,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0xe184,0x0,0x949e,0x0,0xe184,0xe184,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x949e,0x949e,0x0,0x80c1,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x949e,0x0,0x0,0x0,0x949e,0x949e,0x949e,0x0,0x80c1,0x0,0xffdf,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x949e,0x949e,0x7399,0x0,0xff50,0xffdf,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x949e,0x949e,0x7399,0x0,0xec66,0xff50,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0x0,0x7399,0x949e,0x949e,0x949e,0x949e,0x949e,0x949e,0x7399,0x7399,0x7399,0x0,0xff50,0xff50,0xffdf,0xff50,0x0,0xF81F,0xF81F,0x0,0x0,0x0,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x4a51,0x0,0xff50,0xff50,0x0,0xF81F,0xF81F,0x0,0xff50,0xec66,0x0,0x4a51,0x4a51,0x4a51,0x4a51,0x4a51,0x7399,0x7399,0x0,0x0,0x0,0xF81F,0x0,0x0,0xF81F,0xF81F,0xF81F,0x0,0xff50,0xff50,0xe184,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xec66,0xe184,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xff50,0xff50,0xe184,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xe184,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xff50,0xff50,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0xe184,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xff50,0xff50,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0x0,0xec66,0xe184,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xff50,0xff50,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0xe184,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xec66,0xe184,0xe184,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xe184,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0x80c1,0x80c1,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xe184,0x80c1,0x80c1,0x80c1,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x80c1,0x80c1,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0x0,0xffdd,0x0,0xffdd,0xff5a,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0xff5a,0x0,0xffdd,0xff5a,0xf616,0xf616,0x0,0xf616,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xffdd,0x0,0xffdd,0xff5a,0xff5a,0xff5a,0xf616,0xf616,0x0,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xf616,0xf616,0x0,0x0,0x0,0x0,0x0,0xf616,0x0,0xf616,0xf616,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x0,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0xe184,0x0,0x0,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x949e,0x0,0x80c1,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x949e,0x0,0x0,0x0,0x949e,0x949e,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x949e,0x0,0xffdf,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x0,0xff50,0xffdf,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x7399,0x949e,0x949e,0x949e,0x949e,0x949e,0x0,0xec66,0xff50,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x4a51,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x0,0xec66,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x4a51,0x4a51,0x4a51,0x4a51,0x4a51,0x7399,0x7399,0x0,0xec66,0xec66,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xe184,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xe184,0x0,0xF81F,0xF81F,0xF81F,0x0,0x80c1,0x80c1,0x80c1,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xff50,0x0,0xe184,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0x0,0x80c1,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xff50,0x0,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0x0,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xff50,0xff50,0x0,0x80c1,0x0,0xF81F,0xF81F,0x0,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xec66,0xe184,0xe184,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xe184,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0x80c1,0x80c1,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xe184,0x80c1,0x80c1,0x80c1,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x80c1,0x80c1,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0x0,0xffdd,0x0,0xffdd,0xff5a,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0xff5a,0x0,0xffdd,0xff5a,0xf616,0xf616,0x0,0xf616,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xffdd,0x0,0xffdd,0xff5a,0xff5a,0xff5a,0xf616,0xf616,0x0,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xf616,0xf616,0x0,0x0,0x0,0x0,0x0,0xf616,0x0,0xf616,0xf616,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x80c1,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x949e,0x0,0x80c1,0x80c1,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0xe184,0x0,0x949e,0x0,0x0,0x0,0x80c1,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x949e,0x949e,0x0,0xec66,0xffdf,0x0,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x949e,0x0,0x0,0x0,0x949e,0x949e,0x0,0xffdf,0xffdf,0xffdf,0xffdf,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x949e,0x0,0xff50,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x949e,0x0,0xff50,0xff50,0xff50,0xff50,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x7399,0x949e,0x949e,0x949e,0x949e,0x949e,0x949e,0x7399,0x0,0xff50,0xff50,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x4a51,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x4a51,0x4a51,0x4a51,0x4a51,0x4a51,0x7399,0x7399,0x0,0xec66,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xec66,0xe184,0xe184,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0x80c1,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0x0,0x80c1,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xe184,0x80c1,0x0,0x0,0x0,0x0,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xe184,0xe184,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xec66,0xe184,0xe184,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xe184,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0x80c1,0x80c1,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xe184,0x80c1,0x80c1,0x80c1,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x80c1,0x80c1,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0x0,0xffdd,0x0,0xffdd,0xff5a,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0xff5a,0x0,0xffdd,0xff5a,0xf616,0xf616,0x0,0xf616,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xffdd,0x0,0xffdd,0xff5a,0xff5a,0xff5a,0xf616,0xf616,0x0,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xf616,0xf616,0x0,0x0,0x0,0x0,0x0,0xf616,0x0,0xf616,0xf616,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x0,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0xe184,0x0,0x0,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x949e,0x0,0x80c1,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x949e,0x0,0x0,0x0,0x949e,0x949e,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x949e,0x0,0xffdf,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x0,0xff50,0xffdf,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x7399,0x949e,0x949e,0x949e,0x949e,0x949e,0x0,0xec66,0xff50,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x4a51,0x7399,0x7399,0x7399,0x7399,0x7399,0x0,0x0,0x0,0xff50,0xffdf,0xec66,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x4a51,0x4a51,0x4a51,0x4a51,0x0,0xec66,0xe184,0xe184,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0xec66,0xe184,0xe184,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xe184,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xe184,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xec66,0xe184,0xe184,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xe184,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0x80c1,0x80c1,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xe184,0x80c1,0x80c1,0x80c1,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x80c1,0x80c1,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0x0,0xffdd,0x0,0xffdd,0xff5a,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0xff5a,0x0,0xffdd,0xff5a,0xf616,0xf616,0x0,0xf616,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xffdd,0x0,0xffdd,0xff5a,0xff5a,0xff5a,0xf616,0xf616,0x0,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xf616,0xf616,0x0,0x0,0x0,0x0,0x0,0xf616,0x0,0xf616,0xf616,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0xe184,0x0,0x949e,0x0,0xe184,0xe184,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x949e,0x949e,0x0,0x80c1,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x949e,0x0,0x0,0x0,0x949e,0x949e,0x949e,0x0,0x80c1,0x0,0xffdf,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x949e,0x949e,0x7399,0x0,0xff50,0xffdf,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x949e,0x949e,0x7399,0x0,0xec66,0xff50,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0x0,0x7399,0x949e,0x949e,0x949e,0x949e,0x949e,0x949e,0x7399,0x7399,0x7399,0x0,0xff50,0xff50,0xffdf,0xff50,0x0,0xF81F,0xF81F,0xF81F,0x0,0x4a51,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x4a51,0x0,0xff50,0xff50,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x4a51,0x0,0x0,0x0,0x0,0x7399,0x7399,0x7399,0x4a51,0x0,0xF81F,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0xec66,0xe184,0x80c1,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xe184,0xe184,0xe184,0x80c1,0x0,0xF81F,0xF81F,0x0,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xff50,0xff50,0xe184,0xe184,0x80c1,0x80c1,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0xff50,0xff50,0xff50,0xff50,0x0,0xec66,0xe184,0x80c1,0x80c1,0x80c1,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0xe184,0xe184,0xe184,0x80c1,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xec66,0xe184,0xe184,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xe184,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0x80c1,0x80c1,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xe184,0x80c1,0x80c1,0x80c1,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x80c1,0x80c1,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0x0,0xffdd,0x0,0xffdd,0xff5a,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0xff5a,0x0,0xffdd,0xff5a,0xf616,0xf616,0x0,0xf616,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xffdd,0x0,0xffdd,0xff5a,0xff5a,0xff5a,0xf616,0xf616,0x0,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xf616,0xf616,0x0,0x0,0x0,0x0,0x0,0xf616,0x0,0xf616,0xf616,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x0,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0xe184,0x0,0x0,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x949e,0x0,0x80c1,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x949e,0x0,0x0,0x0,0x949e,0x949e,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x949e,0x0,0xffdf,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x0,0xff50,0xffdf,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x7399,0x949e,0x949e,0x949e,0x949e,0x949e,0x0,0xec66,0xff50,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x0,0xec66,0xff50,0xffdf,0xec66,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xff50,0xec66,0x0,0x4a51,0x4a51,0x4a51,0x4a51,0x7399,0x7399,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xff50,0xff50,0xe184,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xec66,0xe184,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xff50,0xff50,0xe184,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xe184,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xff50,0xff50,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0xe184,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xff50,0xff50,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0x0,0xec66,0xe184,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xff50,0xff50,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0xe184,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xec66,0xe184,0xe184,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xe184,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0x80c1,0x80c1,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xe184,0x80c1,0x80c1,0x80c1,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x80c1,0x80c1,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0x0,0xffdd,0x0,0xffdd,0xff5a,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0xff5a,0x0,0xffdd,0xff5a,0xf616,0xf616,0x0,0xf616,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xffdd,0x0,0xffdd,0xff5a,0xff5a,0xff5a,0xf616,0xf616,0x0,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xf616,0xf616,0x0,0x0,0x0,0x0,0x0,0xf616,0x0,0xf616,0xf616,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x80c1,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x949e,0x0,0x80c1,0x80c1,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0xe184,0x0,0x949e,0x0,0x0,0x0,0x80c1,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x949e,0x949e,0x0,0xec66,0xffdf,0x0,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x949e,0x0,0x0,0x0,0x949e,0x949e,0x0,0xffdf,0xffdf,0xffdf,0xffdf,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x949e,0x0,0xff50,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x949e,0x0,0xff50,0xff50,0xff50,0xff50,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x7399,0x949e,0x949e,0x949e,0x949e,0x949e,0x949e,0x7399,0x0,0xff50,0xff50,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x4a51,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x4a51,0x4a51,0x4a51,0x4a51,0x4a51,0x7399,0x7399,0x7399,0x0,0xec66,0xec66,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xe184,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0xec66,0xec66,0xe184,0x0,0xF81F,0xF81F,0xF81F,0x0,0x80c1,0x80c1,0x80c1,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xff50,0x0,0xe184,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0x0,0x80c1,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xff50,0x0,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0x0,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xff50,0xff50,0x0,0x80c1,0x0,0xF81F,0xF81F,0x0,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xec66,0xe184,0xe184,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xe184,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0xe184,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xffdf,0xffdf,0xffdf,0xe184,0xe184,0xe184,0x80c1,0x80c1,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xe184,0x80c1,0x80c1,0x80c1,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x80c1,0x80c1,0xe184,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0x0,0xffdd,0x0,0xffdd,0xff5a,0xf616,0x0,0x0,0x0,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0xff5a,0x0,0xffdd,0xff5a,0xf616,0xf616,0x0,0xf616,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xffdd,0x0,0xffdd,0xff5a,0xff5a,0xff5a,0xf616,0xf616,0x0,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xffdd,0xffdd,0xf616,0xf616,0x0,0x0,0x0,0x0,0x0,0xf616,0x0,0xf616,0xf616,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xf616,0xf616,0xf616,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xf616,0xf616,0xf616,0xf616,0xf616,0xf616,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x0,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0xe184,0x0,0x0,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x0,0xe184,0xe184,0x0,0x949e,0x0,0x80c1,0xe184,0xe184,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0x949e,0x0,0x0,0x0,0x949e,0x949e,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x949e,0x0,0xffdf,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x949e,0xffdf,0x949e,0x949e,0xffdf,0xffdf,0x0,0xff50,0xffdf,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x7399,0x949e,0x949e,0x949e,0x949e,0x949e,0x0,0xec66,0xff50,0xffdf,0xffdf,0xffdf,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x4a51,0x7399,0x7399,0x7399,0x7399,0x7399,0x7399,0x0,0x0,0x0,0xffdf,0xec66,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x4a51,0x4a51,0x4a51,0x4a51,0x4a51,0x7399,0x0,0xec66,0xe184,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0xec66,0xe184,0xe184,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0x80c1,0x80c1,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0xF81F,0x0,0x80c1,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xec66,0xec66,0xe184,0x80c1,0x0,0x0,0x0,0x0,0x0,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0xe184,0xe184,0xe184,0xe184,0x80c1,0x80c1,0x0,0xF81F,0xF81F,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F,0xF81F
typedef struct {
uint8_t x;
uint8_t y;
uint8_t w; // width
uint8_t h; // height
bool orientation; // left | right
int8_t vx; // horizontal velocity
uint8_t frame; // current frame
uint8_t frames; // number of frames
Image sheet; // spritesheet
} Sprite;
Sprite mario = {
.5*(SCREEN_WIDTH - MARIO_WIDTH), // x
.5*(SCREEN_HEIGHT - MARIO_HEIGHT), // y
MARIO_WIDTH, // w
MARIO_HEIGHT, // h
MARIO_ORIENTATION_RIGHT, // orientation
0, // vx
MARIO_DEFAULT_FRAME, // frame
MARIO_FRAMES, // frames
Image(mariodata) // sheet
while (!gb.update());
checkButtons();
moveMario();
drawMario();
void checkButtons() {
if (gb.buttons.repeat(BUTTON_LEFT, 0)) {
mario.orientation = MARIO_ORIENTATION_LEFT;
mario.vx = -2;
} else if (gb.buttons.repeat(BUTTON_RIGHT, 0)) {
mario.orientation = MARIO_ORIENTATION_RIGHT;
mario.vx = 2;
} else if (gb.buttons.released(BUTTON_LEFT) || gb.buttons.released(BUTTON_RIGHT)) {
mario.vx = 0;
mario.frame = MARIO_DEFAULT_FRAME;
void moveMario() {
if (mario.vx != 0) {
mario.x += mario.vx;
if (mario.x < 0 || mario.x + mario.w > SCREEN_WIDTH-1) {
mario.x -= mario.vx;
mario.frame = ++mario.frame % mario.frames;
void drawMario() {
mario.sheet.setFrame(mario.frame);
gb.display.drawImage(
mario.x,
mario.y,
mario.sheet,
mario.w * (mario.orientation == MARIO_ORIENTATION_LEFT ? 1 : -1),
mario.h
I hope you’ll see it through now. Feel free to come back to us if you have any new questions
Thanks again @Steph for this tuto i have post it here to keep it as it was on old forum
Thx for info.
