Take o role of the brevious archeologist and uncover pyramid secrets. In this game you will explore maze, discover treasures and meet dangerous traps.
GAMEPLAY
Your archeologist stats consist of two parameters:
- RED - Health points (game ends, when they fall to 0)
- BLUE - Wisdom points (used to add additional selection of corridors and affect some tresures value)
When you start a new game, you will need to set additional game configuration. Difficulty will affect enemies damage rate and selection of the corridors. Initial stats allow you to select stats proportions.
After setting parameters you start your journey at the pyramid entrance. Your objective: build maze, which will lead you to the center tile of the level. Try to find as much treasures as you can to bolster your score.
Every time you will try to move to the unknown section (marked as eye), the corridor selection screen will be displayed.
Based on the difficulty level you will have to select next tile to move further. If none of the corridor is proper for you, you can use 1 wisdom point (B Button) to get all corridors selection.
After you select specific corridor, the archeologist will move into it. Some corridors will have special events which triggers automatically after selection.
GAME CONTROLS
MENU SCREEN/HIGH SCORES/GAME CONFIGURATION
- UP/DOWN - select choice
- LEFT/RIGHT - adjust initial parameters
- A - confirm choice
- B - move back
LEVEL SCREEN
- UP/DOWN/LEFT/RIGHT - move between corridors/enter to unexplored corridor
- HOME - open map and stats menu
CORRIDOR SELECTION SCREEN
- UP/DOWN - select corridor
- A - confirm corridor
- B - use map (1 wisdom point required)
MAP AND STATS MENU SCREEN
- HOME - return to level screen
- B - yield (finish game with the current score)
EVENT SCREEN
- A - confirm event
TIPS
Your first goal at each level should always be reaching the center tile.
After you make your way to it, then you should try to uncover as many corridors as you can to find treasures that will improve your score.
Use minimap in the stats menu to see uncover corridors (red dots symbols threats, and black ones blocked areas).
If you get yourself blocked, then you can yield from the stats menu to preserve your score.
