Cannot edit creation describtion
Hey. I have just published major update for creation, but after saving describtion for the creation does not update. Is something wrong with mechanism?
Ok, little update - seems, that editor does not save large text inserted at once. I have prepared earlier update description and tried to copy all text and save. I have to divide text to a little portions and then copy and save several times - then everything works. However this could be a real problem if someone type a lot of text at once and save.
argh!
The editor doesn’t seem to work very well.
Thank you for this feedback @sentinel87
I met the same problem as you. Hu hu
