Meta Warfare is a strategy game where you take command over your army and try to beat your opponent.
GAMEPLAY
At the begining you start with only several units and your HQ. After getting access to military base you can unlock new units and build them. At the start all units except INFANTRY will be locked. After gaining enough funds you can upgrade base level (‘UP’ choice) to unlock additional units. Funds can be acquired from captured buildings. Each building will grant you additional funds every turn to buy new units.
There are two map modes:
- CONQUEST - your objective is to capture enemy HQ
- CAPTURE - your objective is to control 8 buildings at the end of your turn
Game content:
- Tutorial mode
- Multiplayer mode (2 players)
- 2 tutorial maps
- 7 maps for 2 players (4 CONQUEST, 3 CAPTURE)
- 8 playable units
- 9 base upgrade levels
- 1 save slot
UNITS DESCRIBTION:
- INFANTRY - basic unit, very weak. It can cross mountains and capture buildings.
- AT INFANTRY - upgraded infantry with weapons to destroy MD TANK and HALFTRUCK. They are slower than standard Infantry, but they can also capture buildings.
- HALFTRUCK - light armored vehicle designed to destroy infantry. It has the highest moving range, but it is uneffective against heavy armored vehicles.
- MD TANK - main offensive unit, it is very mobile and can be use to block early enemy offensive. Weak vs HV TANK and TANK DESTROYER.
- MOBILE ARTILLERY - indirect unit, good in defensive. Has shorter range then MOBILE SSM, but can shoot at point blank range. It cannot defend.
- MOBILE SSM - indirect unit. Has the highest attack range in the game. It cannot defend.
- HV TANK - heavy tank designed to break front lines and guard buildings.
- TANK DESTROYER - the most powerful unit in the game. It has the same firepower as HV TANK, but gets additional attack from the terrain bonus (building, forest).
GAME KEYBOARD:
MENUS:
- A - select option
- Arrows Up/Down - move between options
BATTLE MAP:
- Arrows - scroll map/select unit/select place to move unit/select attack target
- A - select unit/select action in dropdown menu/attack/(on captured base)enter base screen
- B - cancel current action (before pressing A to confirm)
- HOME - open info menu
RELEASE NOTES:
First version does’t have campaign for 1 player (planned to add in the future releases).
