Music player -- By William132
Music Player
Author :  William132
How to add songs:
Add songs by putting the name and .wav file by the orange arrows. Increase each value by the black arrows by 1 every time a song is added. to convert an audio file to a .wav I found this website helpful: https://audio.online-convert.com/convert-to-wav . Change the bit resolution to 8 bit and the sampling rate to 22050. I hope you enjoy using it.   =D
Author :  William132
controls are A to select song, B to return to list, and left/right to skip songs
Cool, thanks for this tools  ;)
Author :  Cyrhades
I have problem because I have create a sound with this website, config like this :
Resolution : 8bit
Sampling rate : 22050Hz
audio channels : mono
PCM format : PCM 8bit unsigned
The sound works,  but it's  very fast (2X speed),  How remedy ?
If I hear on computer the sound works correctly !
Sorry for my  english !
Bye
Bonjour,
J'ai un problème avec un son que j'ai créé à partir du site web conseillé ici, j'ai configuré comme ceci :
Resolution : 8bit
Le problème c'est que le son est lu, mais il va 2 fois plus vite qu'il ne le devrait, pour info quand je l'écoute sur PC le son est à vitesse normal !
Merci par avance.
Author :  William132
only change the bit resolution and the sampling rate. leave everything else. (your English is good :-) )
Author :  Cyrhades
Thanks William132 ;-)
I have change in :
Resolution : 8bit
Sampling rate : 44100Hz
And it's correct now !
Thank you for your help !
And Thank Steph on Discord who help me yesterday ;-)
Author :  William132
no problem ;-)
Author :  locness3
How can I add music ? I don't find the source code @William132
Author :  alxm
Nice work! If anyone's interested in converting songs from the Linux terminal, here's a one-liner:
ffmpeg -i OriginalSong.mp3 -ac 1 -ar 44100 -acodec pcm_u8 ConvertedSong.wav
Author :  William132
It's all in the download file. To add music just open the file and follow the instructions I've put above. Sorry if it's not very clear but I hope it helps. Make sure the music file is in the same folder as the program.
Author :
 locness3
I’m really sorry but I don’t find it. I only have the .bin in the download.
Author :
 William132
There is only a bin file. I am very new to all of this so there’s a lot I still don’t understand or havnt learnt yet.
Author :
 locness3
.bin is a binary format; this means a program without its source code. You would need to provide your Arduino files you use for developement (.ino).
Author :
You drop the folder with the .bin file onto the sd card, and then you can load it from the game loading screen on your meta
