Ecran casse screen not working anymore - By Nux
Author :  Nux
Ma Gamebuino est tomber d'environs 30 cm, la coque c'est ouverte et la batterie c'est décoller, j'ai remonté le tout et l’écran ne marchais plus quand je démarrais la console. En regardant un peu j'ai vus qu'un câble plat  derrière la batterie n'était plus bancher, il y a quelque chose en face qui ressemble a une prise pour le brancher, je l'y ai mit maintenant l’écran s'allume tout en blanc.
Donc je me dit que peut être en essaye de le pousser plus dans la prise ça pourrais marché, mais vus que j'y connais pas grand chose je me dit que je risque de l’abîme si je fait mal, j'attend des retours avant d'essayer de re-manipuler la console
My Gamebuino have fallen from about 30 cm, the hull was open and the battery take off, I reassembled everything and the screen did not work when I started the console. After, Looking a little I saw that a flat cable behind the battery was not plung-in , there is something in front that looks like a plug to connect in, So I put it in. Now the screen s' light all in white.
So I told myself that maybe if I was trying to push it more into the socket that would work, but like I do not know much about it I am afraid to boke it by miss use it so i pref to wait feedback.
Author :  Aurélien Rodot
It's probably that the screen connector got loose. It's on the back of the Gamebuino, to the right of the battery. The cables comes from underneath the battery.
1- Pull on the black thing to get it loose
2- Put the orange ribbon cable back in the connector as much as you can
3- Push back the black thing to lock the ribbon cable in place
Author :  Nux
My screen is working again ! Thanks for the help
