Colorscrolling - By tikkel
Author :  tikkel
Hello!
I wanted to ask if the META also has hardware special effects.
For example, like game consoles, hardwarescrolling, colorscrolling and various graphics modes.
Especially a colorscrolling would interest me.
Greeting from me
Author :  Martisse
I dont think so. But you can add Arduino components with the backpack. Like LED...
The gamebuino has also led . Go to tutorial section to learn it. Go hereTutorial of led
Author :  Alban
It's just a plain Cortex-M0+ architecture, so no gaming-dedicated hardware, but enough horspower to emulate all these effects to a certain extent.
Some games have already implemented rotations, zooms, palette cycling etc.
Some car races for example  ;) You definitively have to make some simple tuto if you can Alban... It's could be useful...
Author :  Alban
I know, but my code is so ugly I would have to rewrite from scratch to have something worth presenting. It was my first gamebuino project, grew organically, and I got so fed up with the Arduino IDE that I ended up writing code as it came.
My next project, if I manage to complete it, is designed a much better way, and in much better conditions ;-) I plan to document it more seriously.
Maybe you could some very short program to illustrate the technics used (and complement the already existing tuto) Your tutos / examples could be agregated later to do a workshop on doing a race car from scratch. (And then your code could be reorganised in the tuto to have a more academic code) but it's another subject. I just bouncing on this subject as tikkel was talking about one of the technics used
Author :  Steph
Try this!
const uint8_t GRADIENT[] = {
16, // frame width
2, // frame height
1, // number of frames
0, // ?.. don’t understand this value
0, // animation speed (0 means no animation)
0x10, // transparent color (any value greater than 0xf is transparent)
1, // indexed color mode
// colormap (2 pixels per byte)
0x01, 0x23, 0x45, 0x67, 0x89, 0xab, 0xcd, 0xef,
0xfe, 0xdc, 0xba, 0x98, 0x76, 0x54, 0x32, 0x10
// must have 16 colors
const Color REFERENCE_PALETTE[] = {
(Color)0x47e9, (Color)0x37e6, (Color)0x1fe4, (Color)0x0fe1,
(Color)0x07a0, (Color)0x0700, (Color)0x0661, (Color)0x05c1,
(Color)0x0501, (Color)0x0461, (Color)0x03c1, (Color)0x0320,
(Color)0x0280, (Color)0x01e0, (Color)0x0140, (Color)0x00a0
const Image IMAGE(GRADIENT);
Color palette[16];
while (!gb.update());
<span class="hljs-comment">// rotating palette</span>
<span class="hljs-keyword">for</span> (<span class="hljs-keyword">uint8_t</span> i=<span class="hljs-number">0</span>; i&lt;<span class="hljs-number">16</span>; i++) {
    palette[i] = REFERENCE_PALETTE[(gb.frameCount+i)%<span class="hljs-number">16</span>];
<span class="hljs-comment">// draw image with new palette</span>
gb.display.setPalette(palette);
gb.display.drawImage(<span class="hljs-number">32</span>, <span class="hljs-number">32</span>, IMAGE);
Only works with indexed images... If you want the same effect in full RGB565, you'll have to write the bits in the right place by yourself!
It's one of the technics for simulate quick races movements. It's can been used to make water, lava, lead, grass moving with good use of colors.
Author :  tikkel
OK,
so I have to paint all the effects.
Unfortunately, it is not possible to manipulate the color palette or image memory address directly on the graphics controller registers.
I was hoping to save some CPU time.
Thank you for the tips and the example.
Author :  Alban
Indeed, there's just no graphics controller :-)
Author :  Martisse
What is a graphics controller?
you can manipulate the color of the palette if you use indexed colors
Author :  Alban
A specialized chip with its own memory for graphics rendering, and sometimes facilities for effects (e.g. the famous SNES mode 7)
The screen controller actually has some hardware effects, such as color inversion. No scrolling, though.
For example. gb.setRotation() also uses screen hardware to rotate the contents
Author :  tikkel
... so I can change a color of the palette afterwards and this change would be visible immediately?
Author :  Steph
Yes, you don't need to redraw the image :-)
Author :  tikkel
Please, what is the default color palette in C++ syntax?
const Color PALETTE[] = {
  (Color)0xffff, // color 0x0 ... ?
Author :  Steph
Image Transcoder gives you the details when you select the indexed mode....
    (Color)0xacd0, // color 0x1
    (Color)0x5268, // color 0x2
    (Color)0x0000, // color 0x3
    (Color)0x9008, // color 0x4
    (Color)0xca30, // color 0x5
    (Color)0xd8e4, // color 0x6
    (Color)0xfd42, // color 0x7
    (Color)0xcc68, // color 0x8
    (Color)0xfeb2, // color 0x9
    (Color)0xf720, // color 0xa
    (Color)0x8668, // color 0xb
    (Color)0x044a, // color 0xc
    (Color)0x0210, // color 0xd
    (Color)0x4439, // color 0xe
    (Color)0x7ddf  // color 0xf
Author :  tikkel
Sure? If i use this, all colors are changed. Not the same as without setPalette ...
(I use  DISPLAY_MODE_INDEX_HALFRES)
Author :  Steph
https://gamebuino.com/creations/color-palettes
