Circuitpython for gamebuino -- By Sorunome
Circuit Python for Gamebuino
Learn Circuit Python
Get started here.
How to install Circuit Python
Download the zip file, extract it, and copy/past the "CircuitPython" folder to the root of your micro SD card.
Circuit Python Reference
All the generic functions (input / output, if / else, etc.) can be found on Adafruit's Circuit Python Essentials.
Find below all the Gamebuino specific supported functions.
(usage is the same as the c++ equivalents)
Things in brackets [] are optional parameters
Base
  • void gb.begin() unneeded!
  • void gb.loader()¬†loads loader, was very useful for testing & re-flashing
  • bool gb.update()
  • void gb.waitForUpdate()¬†waits until next screen update
  • void gb.updateDisplay()
  • void gb.setFrameRate(int framerate)
  • int gb.getCpuLoad()
  • int gb.getFreeRam()
  • string gb.getDefaultName()¬†Pretty useless as SD functionality isn't implemented currently
Display
  • void gb.display.clear([int color])
  • void gb.display.fill([int color])
  • void gb.display.print([int x, int y,] string|int text)
  • void gb.display.println([int x, int y,] string|int text)
  • void gb.display.drawLine(int x1, int y1, int x2, int y2)
  • void gb.display.drawRect(int x, int y, int width, int height)
  • void gb.display.fillRext(int x, int y, int width, int height)
  • void gb.display.drawPixel(int x, int y [, int color])
  • void gb.display.drawCircle(int x, int y, int radius)
  • void gb.display.fillCircle(int x, int y, int radius)
  • void gb.display.drawTriangle(int x1, int y1, int x2, int y2, int x3, int y3)
  • void gb.display.fillTriangle(int x1, int y1, int x2, int y2, int x3, int y3)
  • void gb.display.drawRoundRect(int x, int y, int width, int height, int radius)
  • void gb.display.fillRoundRect(int x, int y, int width, int height, int radius)
  • void gb.display.setColor(int color)
  • void gb.display.drawBitmap(int x, int y, bytes buffer [, int scale])
  • void gb.display.drawImage(int x, int y, buffer image)
Lights
  • void gb.lights.clear([int color])
  • void gb.lights.fill([int color])
  • void gb.lights.fillRect(int x, int y, int width, int height)
  • void gb.lights.drawPixel(int x, int y [, int color])
  • void gb.lights.setColor(int color)
Buttons
Constants :
  • int gb.buttons.DOWN
  • int gb.buttons.LEFT
  • int gb.buttons.RIGHT
  • int gb.buttons.UP
  • int gb.buttons.A
  • int gb.buttons.B
  • int gb.buttons.MENU
  • int gb.buttons.HOME
Methods:
  • bool gb.buttons.pressed(int button)
  • bool gb.buttons.released(int button)
  • bool gb.buttons.held(int button, int duration)
  • bool gb.buttons.repeat(int button, int duration)
  • int gb.buttons.timeHeld(int button)
Collide
  • bool gb.collide.rectRect(int x1, int y1, int w1, int h1, int x2, int y2, int w2, int h2)
  • bool gb.collide.pointRect(int pointX, int pointY, int rectX, int rectY, int rectW, int rectH)
  • bool gb.collide.circleCircle(int centerX1, int centerY1, int r1, int centerX2, int centerY2, int r2)
  • bool gb.collide.pointCircle(int pointX, int pointY, int centerX, int centerY, int r)
Color
  • int gb.color.WHITE
  • int gb.color.GRAY
  • int gb.color.DARKGRAY
  • int gb.color.BLACK
  • int gb.color.PURPLE
  • int gb.color.PINK
  • int gb.color.RED
  • int gb.color.ORANGE
  • int gb.color.BROWN
  • int gb.color.BEIGE
  • int gb.color.YELLOW
  • int gb.color.LIGHTGREEN
  • int gb.color.GREEN
  • int gb.color.DARKBLUE
  • int gb.color.BLUE
  • int gb.color.LIGHTBLUE
GUI
  • string gb.gui.keyboard(string titleText [, string defaultText])
  • int gb.gui.menu(string titleText, [, array[string] entries])
  • void gb.gui.popup(string text, int duration)
Author :  gregvsmj
Au top, j'attendais de voir un exemple de ce qu'allait donner le python sur la Meta ^^ Merci Aurélien!
Author :  JPBONNAFOUS
J'arrive pas à "monter" le volume circuit python sur mon linux mint 18.10 !
Message d'erreur:
Error 2 hard Fault
Appuyez sur A pour continuer
ça marche sur mon WIN7 du taf par contre... mais c'est ma machine du taf :-(
Author :  te3game
C'est génial!
À propos, si j'essaie d'utiliser la bibliothèque CircuitPython avec Gamebuino META, quelle procédure dois-je suivre?
Je pense à utiliser le stockage dans sdcard.mpy etc.
0.0.4 Update
  • Fixed the gamebuino object being cleared by the garbage collector
  • Made calling to gb.begin() unneeded
  • Updated to upstream version 4.0.0-rc1
Yeah!!!
Je viens d'installer la 0.0.4 et maintenant j'arrive à monter le volume circuit python sur mon Linux.
0.0.5 Update
This includes all the gb.collide methods
Author :  Thierry
That's a good pace of evolution, thanks Sorunome.
Author :  te3game
Je ne connais pas la raison.
On a l'impression qu'il n'y a pas eu de problème à 0.0.4.
Le mode coller REPL ne fonctionne pas correctement.
La même chose s'est produite dans le passé, même avec Adafruit Feather.
paste mode; Ctrl-C to cancel, Ctrl-D to finish
=== print("Hello world")
Traceback (most recent call last):
  File "<stdin>", line 1
SyntaxError: invalid syntax
Le problème est résolu.
Le problème est le shell Linux, pas CircuitPython.
Lorsque la commande "reset" est entrée
Le mode coller de CircuitPython fonctionnait correctement.
Don’t update anymore?
Unfortunately time is limited. It should get updated at some point, though.
Still no news of publication of the Gamebuino Circuit Python repository?
This may help.
